vous la trouverez ICI
Voici lemessage d'Igor sur winsoft
What's new in beta #3:
+ Slide-show starts on 30% more quick than in beta #2
+ Slide-show works more smooth on old video cards.
+ Solved problem with smoothness of Pan/Zoom effects because of activity of antiviruses.
+ Loading of slides speeded up in 2 times.
+ Visual editor:
+ Added "Transparent for Click" option for objects. It's useful e.g. if you have "mask" image will cover other objects. An object with this option will impossible to choose visually only via List of Objects.
+ Added "Ignore Not Selected objects" option in popup menu of "Tools" button. It's useful if you need to work with some selected object laying under other objects, and other objects bother to work with that object.
+ Added "Time range" parameter for objects. These two values means time interval where an object is visible on the screen.
+ Press Ctrl+S to quicky save project when you in Visual editor or in "Customize synchronization" window.
+ Filename of selected object displays in the status bar.
+ Added "Undo All Changes" and "Redo All Changes" to popup menu on "Tools" button click in Visual editor.
+ "Add image" allows to insert several new images at once.
+ Thickness of smoothing line in percents now.
+ "Close show after last slide" and "When show ends keep last slide in show on screen" option work again.
+ Almost synchronized start of music. We'll rework work with music in the next beta #4
+ Various other improvements.
* Fixed bug with appearing of horizontal line in slide-show with some aspect ratio values.
* Fixed bug with File Tree when Nero Scout v7.0.1.4 installed. It's was not our bug.
* Fixed bug in "Create backup in ZIP" function.
* Fixed bug with timeline in Visual editor if slide longer than 1 hour.
Music still not fully synchronized. We'll fully comple work on synchronization in beta #4
Thank you for the help and testing of beta #2
Please let me know about any problem you find.
La beta 3 disponible
- medericke
